Help!
HelloNickName
I attempted to change my Public Mobile number and the request failed because the number was inactive.
My account is active, but EverSafe verification sends the 6-digit code to a non-working number, so I am locked out of Self-Serve.
I need a CSA to reset EverSafe verification and reassign a temporary Public Mobile number so I can regain access.
2 REPLIES 2
CSA_PM
Customer Support Agent
Hello @ HelloNickName,
You will need to access the community account in My Settings-Personal-Account Information and verify if the phone number is correct. Then, on the same page, go to Manage Ever Safe ID, check here as well if the phone number is correct, if not, update it. Then log off, log in again, and check once more if you receive the code.
@HelloNickName check if you can get that code through email.  On the screen it is expecting you to enter the code, click Didn't get the code? or  Resend code and then choose Send email
If you can login, go to Profile > Manage EverSafe ID to correct the phone number there
If you still cannot receive 2FA and login, you will need to engage support.  Private message CS Agent at:
