Usb tethering or turning on hotspot not working
Sohum
While I was able to turn on hotspot once, my usb tethering connection from iPhone through laptop was not able to open any websites.
Yesterday, when I looked to try once again, I could not turn on hotspot as it said to contact public mobile.
1) how can I enable hotspot
2) why is usb tethering not working
Please help me out.
2 REPLIES 2
Sohum
It is set to isp.mb.com
@Sohum
PM does not block the use of Hotspot or Data Tethering, so it is a device setup issue.
Please try the following
  1. Reboot the phone and reset the network settings
  2. Reseat the sim card. Turn off the phone, remove the sim for a minute before you put it back in and setup Hotspot again
  3. Check APN, go Settings > Cellular > Cellular Data Network > PERSONAL HOTSPOT / APN , make sure it is set as  sp.mb.com , and Leave Username and Password blank.
