11-04-2025 01:29 PM
Hello,
My hotspot tethering option appears to be disabled. There is no issue in my account. It does not tell m if I over used the data.
I am using S23 and I was able to use hotspot tethering before
I would appreciate if an insight of this issue is provided.
Thank you.
11-04-2025 01:33 PM
hi @Bipol
that is an issue on phone and not PM, PM does not block hotspot
but one thing, make sure you disable Power Saver and Data Saver, those settings on the phone would disable the Hotspot button
