Email Sign up.
Priority
I've heard some rumors among The Community that some have been able to make two Public Mobile Accounts on the same email?
How would that even work, is it just a glitch in the system since the new update? Because in previous times it would always tell you if an email was registered with an account (not letting you use it for sign up again.)
If you did make a new and secondary account with the same Email/Password as on your first one, EverSafe would allow you to do so? And if so, what exactly happens there as a result of that?
I've had people before with only one Gmail want to use it for two accounts and the only solution was to use the actual email for the first account, and than for the second account use the same Gmail with a period mixed in somewhere for the second account. Public would recognize these as two different emails, however the main Gmail got the emails for both since Gmail doesn't count periods and still receives mail.
Priority
I had someone with a mts.net email come to Activate two Accounts however they only had the one email.. for the second account I used mymts.net. it sent the email code and I successfully made both accounts on the same email address, however Public was able to see them as different emails. 😀
(MTS > Manitoba Telecom Services - Email Domain.)
Priority
Update: Today i created my dad a New Account with Public Mobile and I used the same email which I used the last time he was on Public Mobile.
Worked with no issues.
dust2dust
I have seen people having trouble with the gmail + alias method. I use the . method and have no trouble.
@Priority they use email aliases, it 8d a "different" email address but same inbox
I do not advise using it now as it turns out it could have problem with receiving 2FA or reset password message
email is free, why not create a new one? what you can do is to create mail forwarding rule with that mailbox , anything from PM, forward automatically to your main email you want.  It works, I got 2FA email with forwarding instantly
