03-19-2025
08:54 PM
03-19-2025
09:39 PM
computergeek541
I am trying to activate my account but when I log into the app on my phone to download the eSIM, it tries to send the MFA security code to the new phone number which I can't receive because I haven't installed the eSIM yet. Is there a workaround flow where I can get the code sent to the registered email instead? Thank you!
03-19-2025 09:07 PM
Thank you for the reply. It's a brand new number from Public Mobile. I ended up submitting a ticket and am just waiting for a response.
03-19-2025 08:57 PM - edited 03-19-2025 08:58 PM
hi @codethis
if you requested port, the number might have sent to your old carrier's sim card
if you have not get a code on your phone once after the activation is completed, you won't get that option to get the code via email. So, in your situation, you need to ask PM support agent to help
you can submit ticket by direct message:
