Early renewals
Tristencull95
Need to renew monthly plan I’m on the road travelling for work and data ran out… can’t seem to talk to customer service. Help please
@Tristencull95   What plan do you have (or just changed to)?  Not sure how much data you wanting but PM does offer plans with 20GB/$45 or 15GB/$40, or did still have them yesterday when I logged in.
Tristencull95
Thanks Everyone just changed the plan, I’m  going with different provider  after this, barebones plans no good for camp life!!
dabr
@Tristencull95   The current workaround (not confirmed) is to select Plans/Add-ons, Change My Plan, Change at Next Renewal and confirm Change at Next Renewal, then your current plan becomes available to Change Plan Now.  You can also opt to change immediately to a different plan altogether if you need more data.  Reminder about making plan changes (inc. the workaround) if on a grandfathered plan, then that option will not be available to change to currently or in the future if you change to a different plan.
Hi @Tristencull95 we are discussing what to do in this case earlier today
to renew early without CS agent help,
1.  you can try to Schedule a plan change to another plan on next renewal date
2. then go back Chamgr plan again and pick your current plan for Change plan now
let us know if that works
@Tristencull95 a quick way is to just go to My Account and pick change plan to another plan.  z
If you really want to renew early with the  same plan, please open ticket with PM support
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@Tristencull95  No one to talk to here it’s all done online but you can do this yourself
Early renewal
assuming at least that your current plan is still one that is offered .  If you go into your Self Serve account and schedule a plan change to a different plan, the Self Serve page will then alllow you to select your current plan as an immediate plan change if you go back to change your plan again.otherwise you will need supports help with this
