E sim activation
Ali456
I finished the whole activation process on the app paid and everything my e sim won’t activate and my app is asking to send a code to my number I can’t use for the 2 step verification so I can’t use the app or the number
@Ali456 you have removed other sim, physical, or "Turn off" the other eSIM?
try also reboot phone and Reset Network Settings
Last, and agent to re-provision your eSIM (But DO NOT delete your PM eSIM unless support agent asks you to do so)
Ali456
@Ali456  You can get support to investigate for you
send  a  private message   To CS_Agents
@Ali456
iPhone or Android??
Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
@Ali456
Why not? All activation is done through the app. Unless your phone is not eSIM compatible.
What phone do you have?
