New subscription issues
RoseDamaso
I recently switched to public mobile from zoomer wireless, however I am unable to make or receive calls. My old phone plan was cancelled so I am stuck without service. When I call 611 it is asking me to pay again after they have already taken money from my visa. The customer support will not allow me to make a ticket so the system seems to be down. I am at a loss of what to do to get a working phone. Any help would be appreciated.
@RoseDamaso  Yes please  use the link in provided below to contact support to re provision the SIM or use this direct link
send  a  private message   To CS_Agents
@RoseDamaso probably sim provisioning. Easy fix for PM support and you just need to message them:
RoseDamaso
After talking to the Porting team, the number was ported. The problem seems to be with service or something else.
@RoseDamaso
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
@RoseDamaso  Please submit ticket with CS agent to help
