11-09-2023 01:42 PM
Did the line transfer. Clicked to install esim and everything but my phone is on « sos ». Tried the QR code to réinstaller the esim in the e-mail and I get an error message.
Tried removing the old physical sim card, restarting the phone, etc still doesn’t work.
Anyone knows what to do next?
Thank you
11-09-2023 01:54 PM
@Sophie0117 wrote:How do i pm support? It doesn’t find the user…
please open ticket with PM support
11-09-2023 01:53 PM
11-09-2023 01:51 PM
if eSIM not installed, and I think you tried the eSIM QR already, please open ticket with PM support
11-09-2023 01:49 PM - edited 11-09-2023 01:49 PM
First, try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone , disable those non PM sim (eSIM/Physica sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled. Since it is an iPhone, check Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
11-09-2023 01:45 PM
The -SIM does not appear to be on the phone. There is no sim card associated next to the phone number
11-09-2023 01:43 PM
HI @Sophie0117
Check iPhone, if eSIM is installed, then maybe just system setup problem, but you need to have CS agent to check the system, please submit a ticket with them
