Esim did not work
Jim1959
I just signed up and paid but esim did not work. I want to order physical sim card instead.
2 REPLIES 2
@Jim1959
don't give up your esim yet, it is usually just a problem with setting up the esim on your phone.
Do you have an Android or iPhone?
Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, Please open ticket with PM support by  Private message:
slusagm
yes, you can do this. Quickest way is to get a PM esim from Telus or Koodo stores.  Then open ticket with PM and they will update the sim card number for you
to open ticket, just click on the Orange Chtabot icon on the lower right.  Type the question Submit ticket and choose Contact Us and you will get to ticket open screen
