Dropping calls and poor connection
05-28-2019 07:50 AM - edited 01-05-2022 05:07 AM
I recently got a new pixel 3 straight from Google. I switched from an iPhone 6s. Both use nano sim cards so I was able to pop the sim out of the iphone and into the pixel 3.
The pixel 3 seems to drop alot of calls and have poor connection. Like if I call my mom I can hear her fine but she hears me as static and cant understand what I am saying. This also seems to be happening with other land lines aswell. Cell calls dont seem to be effected. I always check that I have good signal before making calls but it still happens.
Could it be I need to get a new sim card?
Phones
05-28-2019 09:25 AM
@Emilyrichter wrote:I recently got a new pixel 3 straight from Google. I switched from an iPhone 6s. Both use nano sim cards so I was able to pop the sim out of the iphone and into the pixel 3.
@Emilyrichter That is a known issue with the Pixel 3. You might want to call Google and ask for a replacement if it's still under warranty.
05-28-2019 09:07 AM
Getting a new SIM card unlikely will help.
If you put the SIM card back to iphone, still same issues? If not, then it is likely hardware issue.
I did a quick google search and other customers like yourself also have issues with the pixel call quality. You might want to do more research.
Here is one article about the issue:
https://www.tomsguide.com/us/pixel-3-call-quality-issues,news-29614.html
05-28-2019 07:54 AM
You could try resetting your network settings.
There were recent service issues.
Try contacting a moderator if you still have problems.
Moderator can be reached at
