Phone troubles
Elford
Unable to access my Voice messages. And also my calls are always dropping why?
2 REPLIES 2
hairbag1
@Elford
"always dropping" ?...how long has this been happening ? What make / model is your cell ? What area are you located ?
So may questions eh !
slusagm
you meant you long pressed 1 and didn't get to voicemail?
try to call voicemail using this number 1-647-580-4001, enter the number and password and see if you can get to voicemail there
if you can access using that number, then it is just a device program, program the number in your phone.  Usually it is under the settings in the dailer app
For calls dropping issue, what phone do you have? try Reboot phone and Reset network settings and it should help
