Network issues
StarrSqueeze
So i am having problems staying connected to the public mobile network. i have a public mobile esim on my phone and my phone keeps dropping calls / loosing service mainly when I get phone calls or try to call out. Why is this happening and how do I fix it?
7 REPLIES 7
@StarrSqueeze wrote:
It doesn't change until I get kicked off the network LTE it says
HI @StarrSqueeze
so, does that mean it works or not?
you have an S24FE, it is on PM's VoLTE whitelist so you shouldn't be impacted by the 3G-850 realignment
if it still does not work well, ask PM to check and refresh the account:
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
StarrSqueeze
StarrSqueeze
I have a Samsung 24FE and I have tried resetting the settings a few times.
slusagm
What phone do you have?
Try Reset Network Settings
But if you have an "overseas" phone, it might be affected by the recent change to 3G network, the realigning of 850 band in some area:
https://www.publicmobile.ca/en/get-help/articles/850-turndown
StarrSqueeze
I tried that already
TheSterlinger
What type of phone do you have? When you make a call, what is the status in the upper right corner?
Does it show 3 or 4g? Public Mobile has been making changes to their 3G band lately so that could be why you are experiencing the dropp and lost calls.
Your phone must be voLTE on Public Mobile's whitelist to ensure seamless voice.
Read more here and see if this pertains to you.
Chalupa_Batman
Hello @StarrSqueeze
Go into your Settings, find Network Settings and refresh them and reboot. This should help you get connected to the Public Mobile network properly.
