transfer number
Martyna16
Trying to log in but site wants to verify with SMS of the landline number that didn't transfer
2 REPLIES 2
Martyna16
Thank you.
slusagm
If you submitted port request for landline, it will take as many as 3 to 7 days and you won't be able to login My Account until the port is donewhat are you trying to check? You need to ask PM directly for now
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
