Unable To Connect To Network July 15, 2025
Leslie14
July 15th, 2025
Is anyone else having issues with connecting to a mobile network? I cannot make or receive calls. So frustrating. I've exhausted the PM  troubleshooting list, but still no connection. Please help as this phone is my primary form of communication.
CSA_PM
Customer Support Agent
Thank you for the escalation! The customer has already opened a ticket and will be assisted by an agent as soon as possible.
@Leslie14 I have escalated your issue with PM on behalf.  They will reach out to you within an hour.  Please monitor your community inbox for their reply
Leslie14
I have tried all you have suggested. My phone is on the list, so shoukd be working. I need help asap. Cannot connect to network. Emergency calls only.
@Leslie14
Try reboot your phone and try Reset Network Settings
If possible, test your physical sim card on another phone
And voice is the only issue but data works?
What phone do you have?
If your phone is not on PM's VoLTE whitelist ( https://www.publicmobile.ca/en/on/get-help/articles/volte ) , then it will be using 3G for voice and it might be affected by this:
Telus is currently  refarming the 850MHz band 5 spectrum and hence you are left with 1900MHz for voice calls.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
While one compatible band is still sufficient, reality is  1900 MHz could have less coverage, depending on your proximity to a tower and hence you are seeing a poor or no coverage with voice  (Data is not impacted as your phone has the compatible bands on 4G/5G)
If this is really what affecting your voice calls, there is really nothing much you can do other than getting a phone that is on PM's own VoLTE whitelist
