Downgrade plan
weiyiluo
I am an old customer and still using the pitiful $25 1G plan. If I change to the lower $15 plan, will the original data bonus still be retained? Including the recent 30G and the previous 2G per year, as well as international long-distance call minutes, etc.
2 REPLIES 2
Chalupa_Batman
Hello @weiyiluo  If you lower your price plan to a lower plan, you will still keep any More The Merrier gifts given over the years that haven't been used. However, with the loyalty data Public Mobile gave you, you will lose it. However, you can create a ticket and speak to a CS Agent about it.
@turtleTurtle wrote:
Yes you will loose the 30G, everything else will remain.
@hTideGnow wrote:
HI @weiyiluo
if you downgrade your plan, you will loss the recent 30GB bonus
Other bonus you got from before or addon you bought will be there still
To Submit a ticket, please click the following link to access the Public Mobile Chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
HI @weiyiluo
