Does anyone like Public Mobile?
boomerangfarm
I'm only still here so I can get a refund for more service I didn't receive, but how long until I can work that out?
24 REPLIES 24
Belfry
I had an issue with my text messages for a few weeks , it turned out my sim card got damaged when putting the sim tray in my phone. I put a new sim in,so far so good.
CountyDownIeUk
Yes I do. And I have 3 accounts.
Service always works
Billing has never failed
Any CSA issue has always been resolved to my favour.
The frustrating things are.
1. Keep refreshing the look of web site....but is still not efficient and has errors and omissions
2. Make the site work and be complete, listen to us, which will reduce community and CSA help
3. The self inflicted problems and need for help in general, will always be here....and help will be too.
boomerangfarm
Things have now been worked out, and I do feel happy about the result.  Thank you for your recognition and advice.
dabr
@boomerangfarm   Sorry to hear about your experience with roaming add-ons and you're not the only person complaining as we've seen many posts similar to yours saying they were unable to use the roaming add-ons when in the US.
If you're getting the run around from CSA's, I'd ask them to escalate your request for a refund/account credit to a more senior personnel, perhaps a supervisor or even the community manager.
Alexandf
@boomerangfarm
never, go to any store walmart in US to buy it prepaid US sim card or from online amazon ca.
ShawnC13
I have used the US add-ons plenty of times in almost 6 years here.  Currently with the US  shutting down it's 3G network I would personally just buy the texting, and data ROAMING add-ons.  I have a family member in the US right now and these are working fine.
boomerangfarm
When you spend $20 on a US plan and you don't get texts, can't send them, can't make calls or receive them, and your data works maybe for 5 or 10 minutes as you are travelling with children.
boomerangfarm
US add ons, they did not work AT ALL.
boomerangfarm
US roaming package worked not at all created major dilemmas
boomerangfarm
I have contacted an agent.  If you don’t go to the US maybe all is peachy.  I’m not a fan at all of this process, has taken many hours to get not quite resolved.
boomerangfarm
US package worked not at all, created major problems, looking for refund, not endless conversations
boomerangfarm
Maybe I will get the refund for the US package that didn’t work.  Still trying.
boomerangfarm
If you have issues, I find this process a major drag
boomerangfarm
Ever ordered US package?  Do be done so twice.  Don’t do it, get a burner, still trying to get refund for absolutely zero service.
boomerangfarm
I have done that still trying thanks.  Have you ever ordered a US package?
@boomerangfarm
It has been about 1.5 years with PM.
Happy with PM so far. My monthly bill is ranges from $5 to $13 with my all my rewards on a $25 plan.
Only ran into one issue which was a backend issue with my SIM. The CS_Agent took care of it.
NDesai
I love Public Mobile! Never had any issue in 6+ years. Despite some glitches others experience with payment or self-serve, rarely anyone suffers from using services once they are set up properly.
JL9
Yes I do, thank you for asking 😄
Alexandf
@boomerangfarm
send private message PM support CS_Agent at: to get refund
(envelope icon on the top right) CS_Agent will reply you there.
hairbag1
Talk, text and a bit of data...starting at $15.
Available to buy short-term add-ons for travel to USA.
Rewards or Points to bring down already inexpensive plan.
Inexpensive long distance calling add-ons to a lot of foreign countries.
24/7 customer support via Community Forum members.
What's NOT to like ?  What issue are you having that seems to be causing you grief ?
BCW
Works fine for me, never had any problems 🤓
hi @boomerangfarm what you meant by " more service I didn't receive, "?
Something on your plan didn't work?? what is that?
Personally, I love PM.  Plans are cheap, at least the $15 and $25 plans are both great.  Rewards make the plan a lot cheaper.
Yummy
No issues here. PM provides essential service meeting my needs.
If you would present your problem we could try to assist. For account issues contact agent.
Outdoorsman
@boomerangfarm hi I don't understand your issue would you mind explaining?
