05-29-2024 03:47 PM
05-29-2024 06:33 PM
Yes, US roaming will work anywhere their is cellular service in any US state including Alaska
05-29-2024 04:12 PM
You will need to connect to AT&T or T-Mobile network in your network settings. Whichever is available where you are at.
05-29-2024 04:09 PM
You may want to manually connect to the AT&T network when in Alaska.
It would help if your device was VoLTE enabled as far as calling goes.
Make sure your roaming switch is toggled "ON" when in US.
05-29-2024 03:51 PM
@Jcf96 YES
