02-16-2023 04:16 PM
I use a Google Pixel 5A 5G, but I could not stop the phone to send notifications to 7723 while roaming in US. Any idea how to?
02-16-2023 10:09 PM
HI@Facebookphobic It is Google trying to enable visual voicemail It sometimes happen when you are connected to PM as well. I think because T-Mobile has VVM and hence the phone will try to enable it
Try this:
At Phone app, click Settings,
Click, Voicemail.
then disable Visual Voicemail
02-16-2023 09:32 PM
@Facebookphobic - try disabling Visual Voicemail from the dialer setting, send an SMS to 7723 and it should stop.
02-16-2023 04:57 PM
Thanks!
02-16-2023 04:27 PM
This post explains the 7723 messaging and how to disable it.
