12-12-2019 02:34 PM - edited 01-05-2022 08:30 AM
12-12-2019 03:13 PM
Best to contact a moderator by clicking question mark, bottom right, and follow instructions.
12-12-2019 03:00 PM
@Jackhyf63 wrote:@Maryphillips If you are sure that everything is good on your end you can send a private message to the mods to ask them to check.
@Jackhyf63 PM is encouraging everyone to first submit a message via SIMon as responses will be prioritized over the regular private messaging system.
OP can click this link: https://publicmobile.ca.ada.support/chat/
Type in 'rep', select 'contact us', select 'submit ticket' and follow the prompts to finish submission.
12-12-2019 02:56 PM
12-12-2019 02:51 PM
@Maryphillips, please check the APN settings on the phone. The settings should be as follows. Refer to the following knowledge base link on setting up the APN.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
12-12-2019 02:45 PM
What phone do you have? You might need trying a network reset or factory reset.
12-12-2019 02:40 PM
Hi the man at public store checked all APN for me yesterday and still can't send or receive any pics or MMS
12-12-2019 02:38 PM
you must enable data on your phone to send a picture message. You may also need to verify your APN settings are correct.
12-12-2019 02:36 PM
What phone do you have? What are your son settings? You do not need a data plan to send MMS
12-12-2019 02:36 PM
Make use you enable data inorder to send MMS even though it does not use data.
