Data working but calls and text not working
ArthurA
Data is working but not text nor calls
I've restarted my phone, checked my SIM status, ensured I'm not on airplane mode and still no luck. I tried adding a 1 in front of the numbers and haven’t recently changed phones. I used all my data this month but added more and used only 7 minutes of calls. People send me texts that I don’t receive and when I try calling there is a mess That says I have no more minutes…any ideas?
self solution removed/solution re-assigned
@ArthurA  Glad to hear it 🙂
ArthurA
Resetting the network WORKED!!!!
Thank you so much Handy1 !!!
hycm53
Are you just porting your previously phone number to PM? If this is the case you may wait a while for call and text to work as some member of this community said.
After 2 or 3 days, if call and text still don't work, there are 2 methods for help:
  1. Chat with Simon for help, if Simon can’t help, he would let you submit a ticket.
    https://www.publicmobile.ca/en/on/get-help
2, If have issue with Simon, send private message to CS_agent for help:
@ArthurA  Try resetting network settings or test SIM card in another phone . Also can you try putting your network to 3G and see if that helps at all
