Data won't work in US
Babydoll8279
I currently have fhe lan for Canada and US so my service works in both countries but my data isn't working. Last time I was here my data would wodk for a bit and then it wouldn't and it kept doing that continously. Ive done all the steps to try and fix it but ita not working still
Priority
Is your Network Selection set to Automatic or Manual and are Roaming settings Enabled?
DennyCrane
Definitely check to make sure you've enabled data roaming in the network settings on your phone. Also where are you in the US?
dust2dust
So you've already turned on roaming data and then also cellular data? If you're connected to T-Mobile then maybe also try AT&T or vice versa.
You may be in and out of coverage areas.
