Data usage
09-01-2022 04:29 PM
Hi! My plan renewed in aug 15th and it says I have used all 5 G of my data already. I don’t think this is possible? I looked up and added up my data usage and it adds up to 1569 mb? How can I find out why they think I used all of the 5G? Or get it corrected?
My Account
Plans
09-02-2022 07:10 PM
i hear you,, but how can you proof it's one app can be run all your data for one day. no one can check your device what it's run programs on it if your all apps it's on background it's will be you don't know using all your data ... but you have to check it out which app it's run your data.
go to your setting and mobile data usage and see which app run more and do something in your app maybe it's autoplay vidoe, to you go to setting app to turn off. you know.
09-02-2022 07:03 PM
@Denise123 are you on Android or iOS? Best way to track is to use your phones tracker if you are on Android
You can also download the Usage history and examine the usage carefully
09-02-2022 07:02 PM
Go through your usage details in the account from your last renewal and add up all the numbers of MB's used. That will tell you where the system thinks you're at. Apps can go rogue, the OS could update on data, apps can update on data.
09-02-2022 06:55 PM
That is the issue. It says I have no data left and I can't see how I used 5g in 15 days I think it is incorrect how do I get that looked at? I am using a different wifi for this tablet I am on right now
09-02-2022 06:37 PM - edited 09-02-2022 06:40 PM
you use Chrome from browser tablet ok then go view in desktop mode.
- Tap on the menu options.
- Select the checkbox against the Desktop site.
- and clear cache and cookies and use one page incognito.
here photo View Desktop Site. is will be wroks jus fine.
so the data on tablet is working,, or you have phone and tablet and you do switch your SIM card to on both right.
and if your phone device not working data tried to reset network and > APN Settings
and turn off and turn on.
if you don't know how to do it,, what the brand and model will provide you in photos or video..
you are sure you have data left in your account.if you not have it then buy it Add-ons or waiting until next cycle... and for those message you get it just ignore them reading and delete..
and check your device been turn off background data for all apps. to save your data..
09-02-2022 06:28 PM
@Denise123 if you see it showing you maxed out your data, then the text you got was correct.
Now, you can see if your phone can tell you what app used your data.
If you are on Android, the data usage page will show you how much data you used and which app used most. Make sure you update the cycle start date there to match your PM cycle start date
But if you are on iOS, it does not have the feature for you to trace your data after
09-02-2022 06:27 PM
I also just signed in with incognito and it still shows all used how do I get that reviewed to make sure it is Correct?
09-02-2022 06:25 PM
@Denise123- As mentioned earlier, did you click on the little spinner refresh icons lower down? Maybe you'll get different numbers. Maybe you have a rogue app hauling down your data. Are these texts from 611?
09-02-2022 06:22 PM
I am on my tablet now on chrome , I have cleared the cash etc still says I am maxed , data on phone doesn't work anymore , sorry I am not the most technical smart person
09-02-2022 06:21 PM
@Denise123 the website data you see could be cached. Try login again using Incognito mode or a different browser like Edge/Firefox/Chrome for up to date info
09-02-2022 06:20 PM
I got a text message from public mobile saying I am now at 100% and my data is now off how do I dispute this?
09-02-2022 06:19 PM
Hi, I got a text message saying I am now at 100 % and my data doesn't work anymore. When I go to the website it says I have 1.28g left but I still don't know how I did that much. I just use Facebook and not alot
09-01-2022 05:25 PM
maybe it is just a glitch in the system there is a new design ,and just use browser from computer,and clear cache and cookies and use one page inPrivate mode, or safari on private mode,To Login Page
in main page click the little circular arrow icon in the bottom right corner to updated.
or call *611 press 3 and you need your 4 digit PIN and check it out data usage.
you will see it a different..
09-01-2022 04:33 PM
@Denise123 hi what you see in your self serve may be a cached version of you data , clear your cache and cookies or try a different browser in secret or incognito mode , reboot your device and sign back into your account and see if it updates
09-01-2022 04:32 PM
With this new site, you likely still reading off the cached version, so the usage you got was not up to date
Try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome. You should then see the latest usage from the server
Also, if you are on an Android phone, you can check your usage from your phone's Mobile data usage page. Just make sure you change the cycle start date to match your PM's cycle start date, (15th in your case)
