Data usage
Ha100
Wondering if my data plan will be accessible in the US?
2 REPLIES 2
hi @Ha100
what plan do you have?  If yours is a Canada -US plan, then your data can be used in US.  If not, then it will be Canada only
To confirm, login. My Account and go to Subscription and Add-ons page to check the plan details
KZ1964
If you have a Canada/U.S plan you will be able too.  If you dont then would have to purchase a US add on or change your plan to Canada / US but remember if you change plan to more expensive and come back and want less expensive olan yoy may not be able too
