11-23-2024 09:16 PM
I'm in LA. I have data and SMS, but no voice calls. I'm on T-Mobile LTE network. Other networks don't work.
Service
11-24-2024 09:51 AM
Hi there,
Thank you for reaching out! My name is Maria and I will gladly assist you with this.
Please open a new conversation, a private one so we can check your account
Respectfully,
Maria_G
Public Mobile CS_Agent
NOTE: Do not reply to this email address: community-notifications@publicmobile.ca. Please log in to the Community to reply via Private Message
Please note that this is not a Live Chat. We are handling multiple posts at a time so it might take a while until you receive a response.
11-24-2024 09:37 AM
Reset your network settings and try again. This worked for me to solve a similar issue when I changed my number using the app.
11-23-2024 09:39 PM
S20 is not on the whitelist 😞
you will have to rely on the T-Mobile 2G option, which I understand is not reliable
So, a better workaround is to use a VoIP apps to make and receive calls using the number assigned by the VoIP app
11-23-2024 09:37 PM
I don't have VoLTE option. It's a Samsung S20 5G.
11-23-2024 09:31 PM
Selecting 2G (GSM only) works for voice, but it cuts off data.
11-23-2024 09:21 PM
@Likambo2007 If your phone not on the PM volTE white list making voice calls could be difficult. If it’s not on the list you have to try phone set to 2G/3G and connect to T mobile
VoLTE white list
11-23-2024 09:19 PM
hi @Likambo2007
Your phone might not be on PM's VoLTE whitelist. Although one reported that PM has opened up the list to more phone, but that was not confirmed
try change the network mode to 2G and test calls again
11-23-2024 09:17 PM
what phone do you have? it could be a lack of VoLTE issue (or your phone not whitelisted on PM's VoLTE list)
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
