04-07-2025
09:12 AM
04-11-2025
08:03 PM
Dunkman
I have been receiving complaints from family and coworkers that my phone when called goes straight to voicemail. I would like this stopped by increasing the rings to 5 before the call is picked up.
04-07-2025 11:22 AM - edited 04-07-2025 12:19 PM
If your cell phone always goes to voicemail without ringing, check for "Do Not Disturb" or "Focus" mode, call forwarding, or network issues. Also, ensure airplane mode is off and your SIM card is properly seated, and consider contacting your mobile provider for assistance.
04-07-2025 10:19 AM - edited 04-07-2025 10:21 AM
@Pennnye try this see if it will work for you.
Dial: *61*16475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait from above - choose from the following options:
For one ring, enter 5
For two rings, enter 10
For three rings, enter 15
For four rings, enter 20
For five rings, enter 25
For six rings, enter 30 (This is the maximum number of rings/seconds).
