10-02-2022 10:29 PM
Hi,
I checked the speed test on fast.com data is very slow 560 kbps my plan is $55 but 4Gb not able to use can any one help this issue
10-02-2022 11:42 PM
@muhammadaziz786 wrote:No I don't switch but I activated today .I checked it's on LTE 4G selected yes tomorrow will check different locations
I do suspect that your speed issue is localized. It could be the result of bad signal strength or it could be a network capacity issue (too many using the service in that area).
10-02-2022 11:40 PM
@not-trust-anyon wrote:reset network settings and check APN and reboot phone.
APN settings don't control speed.
10-02-2022 10:45 PM
@muhammadaziz786 it could be location related
where you are at? Province and city?
and what phone do you have? brand and model?
Since your account is new and your phone just used in PM , it helps to try Reset All network settings on your phone. But please note this will also clear your saved Wifi network and you have to rejoin them
10-02-2022 10:37 PM
10-02-2022 10:32 PM
@muhammadaziz786 did you just make a plan change from 3G speed to 4G? usually it take 48 hours for the new speed to come
Of course 560 kbps is a bit slow even if it is 3G speed. Check what is the Preferred network type setting. Is it set to LTE or some settings include LTE or 4G?
Also, did you try to run the test in different area instead of just one particular spot?
