11-29-2024 02:08 PM
Hi,
Saw that some people have the $20/month 3GB plan on 4G speed. How do I subscribe to that?
11-30-2024 06:29 PM
are you on a 15$ or 19$ plan? I got the 20$/3gb offer while on the 19$/1gb plan
11-29-2024 02:23 PM
@tabbeykat the only way is to sign into your account and check to see which plans are available to you and then select the one you want. Not all plans will be available to all customers, it seems to be targeted based on whatever your current plan is. From what we have seen, must customer are finding very few options for cheaper plans if any. If you find a plan you like remember to select "Change on renewal" otherwise you risk losing/forfeiting any unused days/data that you have already paid for
