My account login page doesnt work, its static and just shows telus in address can this be fixed?
Bonet
 in all browsers on my phone the login shows as above and after logging in just loads this page again.   It seems to be since telus took over. please fix this so i can manage my account on my phone.
18 REPLIES 18
Bonet
 in opera i can switch to desktop mode shown but clickkng on login i get the same jumbled login form.
@Bonet yes, there should be no difference with wifi or mobile data.  It is likely a page rendering issue.    Not sure why the other member asked
Bonet
pardon?  using data or a wifi connection has same result.
Bonet
tired these and nothing
Bonet
i have also tired my browser settings and requesting the desktop site.  still shows the same.
Bonet
i did try this and still issues.
will13am
@Bonet , the self serve redesign was fairly recent.  Interestingly the redesign was intended to make the self serve more mobile friendly.  Perhaps try using incognito mode on your mobile browser and see if that resolves the problem.
Bonet
cleared cache.  and incognito mode. as well as private mode same result.
Bonet
chrome.  google.  safari.  i had other ones downloaded but it all shows the same.  as u see the links are even behind the input fields.   thats beyond a browser issue.
Bonet
yes it works on the computer.  no problem.
chrome, and safari. on ios  it worked when i first signed up.  now it doesnt since maybe june.  its getting frustrating since i like to purchase more data at times i really need it on the go.
@Bonet wrote:
every browser is the same on my mobile. and i dont want to have to use my laptop since majority of the time i dont have it with me hence needing it on my phone.
@Bonet   At least try once on the computer to confirm if it works there
And to confirm, which browser you have tested on?
Bonet
the page doesnt continue to the my account overview page it just refreshes to this one.
@Bonet wrote:
nope! its that it doesnt go to my account page after logging in and appears jumbled.  see the photo.
It could be a browser rendering issue.
What browser are you currently using ?Try a different one, maybe Chrome ?
Bonet
Bonet
Telus purchased Public Mobile serveral years ago. Is your concern that it says Telus instead of Public Mobile?
will13am
@Bonet , that is actually the correct URL.  Things changed ever since the self serve portal redesign.
