Cannot make or receive calls
rwong31
Need help as I’m not able to make or receive calls.
7 REPLIES 7
@rwong31 wrote:
Network reset did the trick. Thanks for solution
self solution removed/solution re-assigned
Glad you are all fixed up now @rwong31 .
So technically, your solution is by @Dunkman who suggested to try the Network Reset:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Cannot-make-or-receive-calls/m-p/884864/h...
It would be best if you revised your choice of solution to Dunkman's, as they were the first one that posted that. 🙂
rwong31
@rwong31 , was this plan upgrade done as part of renewal?  There's a bug that affects functionality.  If this is the case you will need to initiate a support ticket by using the chatbot link at the bottom of the webpage.
rwong31
Recently upgraded plan. Cel data works.  Just cannot make or receive calls.
Dunkman
@rwong31
Is your account status active?  Is text and data work?
Basic troubleshooting advice:
Reboot phone.
network reset of phone.
Try your SIM card in another working phone. That would help determine whether hardware issue versus PM service problem.
RossN
@rwong31 hi did you just activate an account? does anything work? more info please
