Data not working
10-17-2022 03:17 PM
I added data for my trip from Canada to USA for 10 days. First day worked; now not working. Reset my phone and still not working.
Add-Ons
10-17-2022 04:51 PM
@Ccp176 - when did you add the US data add-on. The 10 days starts the minute you add it.
10-17-2022 04:39 PM
@htrancanada2023 wrote:Try to restart your phone and it'd work!
While that is something to try, there isn't any way to know for certain if that would work.
10-17-2022 04:32 PM
If it could be that simple we would not have zilion posts 'US add-on not working'...🤢
People are not reading posts here, buy blindly add-on which seldom works.
10-17-2022 04:18 PM
10-17-2022 03:51 PM
10-17-2022 03:49 PM
https://www.fcc.gov/consumers/guides/plan-ahead-phase-out-3g-cellular-networks-and-service
Mobile carriers are shutting down their 3G networks, which rely on older technology, to make room for more advanced network services, including 5G. As a result, many older cell phones will be unable to make or receive calls and texts, including calls to 911, or use data services. This will affect 3G mobile phones and certain older 4G mobile phones that do not support Voice over LTE (VoLTE or HD Voice).
10-17-2022 03:48 PM
@will13am...
I don't believe it works on Verizon network either...but...sometime in the last few weeks, that suggestion was put forth by CSA.
10-17-2022 03:34 PM - edited 10-17-2022 03:45 PM
@Ccp176 , the roaming partners are T-Mobile and AT&T. Do not try to connect to Verizon, it won't work. That network runs on a completely different standard. Make sure that roaming data is enabled. By chance is all the data consumed?
10-17-2022 03:20 PM
Turn off Automatic network selection and select T-Mobile...see if that works. Try AT&T...see if that works. Try Verizon...see if that works.
Let us know which works...if any.
I found data works best in urban areas...not so much in rural areas of eastern Washington state.
