Data not working on iphone and calls going to voicemail
shakti
hi
i am using iphone 13 data is not working for me and some calls going directly to voicemail.
my plan is active as per self service.
please advise
thanks in advance
@shakti
There also seems to be cellular issues with older iOS so check to see if your phone is on iOS 16.4.1.
@shakti  After trying as @softech  mentioned also check to see that you have data left like this
simply try refreshing the page when logged in
@shakti does data ever work on this iPhone ??
 start with updating the Carrier profile
Try changing the network type back to 4G ( do not leave it with 5G).  if 4G does not work, change it to 3G and test
if still does not work, click Reset All Networks , then make sure network type is 4G and not 5G after the reser
Add:
Update Carrier Profile
  1. Make sure that your device is connected to Wi-Fi or a cellular network.
  2. Tap Settings > General > About.
  3. Follow the onscreen instructions to install your carrier update.
Change Neteork type
Touch Cellular. Touch Cellular Data Options. Touch Cellular Data Options. Touch Enable 4G to use the 4G network
