Data not working inspite data left on the account
04-02-2023 05:46 PM
Hello
my data is not working inspite I have lot of unused dats left, please help, thank you.
Service
04-02-2023 07:22 PM
here's the little spinner that someone else referenced. Log in on a laptop and try this..
It'll give you an up to the minute idea of how much data is really available on your current account.
04-02-2023 05:55 PM
@vishmekr You could be seeing old cached info and you have used data more than you think. Login to My Account again using Incognito mode.
Also, check if you habe setup data limit on your device, check and disable it if you did
and of course, try reboot the phone
and test in data in another area , wonder if it is local network issue
04-02-2023 05:52 PM
Data is on
no data limit set,
04-02-2023 05:51 PM
To really check account status: Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Did you try to do hard reboot your phone?
Remove SIM and put it back (while phone is off).
04-02-2023 05:50 PM
Click on the little spinner refresh icons lower down to be sure you're seeing current info.
Is your cell data on?
Do you have a data limiter set?
