Data not working iPhone 6s
Aisling93
Call and text working. Data is not. Tried to change APN , still not working. Not sure what's wrong. Tried turning it on and off, airplane mode etc . Still not working,
8 REPLIES 8
Cyberbeagle
Make sure your Cellular Data is on and that all Apps that you use data with is on also.
Go to:
Settings > Cellular Data
You should see something similar to this...
Cellular Data = ON
Cellular Data Options = Roaming Off
Personal Hot Spot = OFF
Carrier Services
Network Selection = Public Mobile
Cellular Data Network
SIM PIN
Current Period = 5GB
Current Period Roaming = 0 bytes
***Turn on all data for Applications you use ***
e.g. Google Maps = ON
CalgaryBen
@Aisling93 specifically, this may be apropos to your situation:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323130/highlight...
krazykiwi
Hi, if you are still having issues let us know. I use an iPhone 6 and have done many troubleshooting tests with it.
will13am
@Aisling93 , give this Apple support page a look.
https://support.apple.com/en-ca/HT201699
frank312
cell phone setting-----cellular data-----turn on cellular data
Lieux
Which plan do you have?
hairbag1
Has it been working up to now ? Is it possible you've run out of your data allotment ?
