Data Use Incorrect
kav2001d
So anyone else notice data use (as listed in online details) is wildly different than what Public claims you are using?
My account shows 100% of data use, yet if I go into details there is about 15GB used in past 60 days (from a 75GB plan so should be nowhere near my limit)
The website / app are very broken or something else is not working in backend correctly
1 REPLY 1
hi @kav2001d
it could be just a browser cache problem.  Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
