04-14-2018 10:40 PM - edited 01-04-2022 04:06 PM
I bought new sims for our unlocked phones and got a plan with unlinuted sms, mms and calling and 1gb. Data and sms Nd data wont work at all????
04-15-2018 12:32 AM
My texting is working now but not my data? I have a plan with data i paid for it so whatdo i do now?
04-14-2018 11:21 PM
@Jdockstater, Are you sure your phone is compatible with Public Mobile's network? Have you checked the APN settings on your phone. if they are not correct, you will not have data.
You can check for your APN settings at the following web site. Just select your Make of phone, Model and then select the network (Public Mobile) at the bottom, and it willshow the settings you need.
https://apn-canada.gishan.net/
