Data usage beware
Westcoast123
Hello. I have the Canada 🇨🇦 USA 🇺🇸 plan. I purposely used all my monthly data so I could feel special about using some of my big data gift we all received.  I roam constantly where I live on the west coast and guess what?. You can't roam with the data gift so I have to purchase add on now to get me through the month so we'll played Telus. Well played!
colleeno
@EB0 wrote:
it will be cheaper to renew your plan early, instead of buying roaming add-on
Renewing their plan early will be the most economical way to deal with @Westcoast123‘s problem.
HALIMACS
Thank you @Westcoast123
I  wondered if that data was limited to Canada only.
I shouldn’t be surprised to learn that it is. 🙄
EB0
Sansan
Yea, unfortunately, the data is not for roaming.  Wouldn't it have been good for them to tell us before.
slusagm
this is normal, the bonus data are Canadian data only
you might want to upsize your plan.  There are still other Canada/US plan with big data
