06-25-2024
03:52 PM
06-25-2024
03:55 PM
computergeek541
06-25-2024 05:22 PM
If your phone supports ESIM, just purchase E-SIM from the app, it will be fast and cheaper
06-25-2024 04:04 PM
a quick way is to get a new PM sim card from local stores, just login the account online and update the sim card number
or if you want, ask support to check first. But you need to open ticket first and they will reply your community inbox
06-25-2024 04:02 PM
i have tried 3 devices, no luck the sim card worked for 5 min and then stopped, something to do with the sim card for sure.
06-25-2024 03:54 PM
do not put your phone number here, it is a public forum. And PM won't call you, they don't even monitor the message here
your sim card, did you reboot the phone? can you try it on another phone? is this for new activation?
if you need support to check your case, please open ticket using the Orange Chatbot icon on the lower right
