05-07-2023 12:49 PM
How long does it usually take for customer service to respond to an issue? I ‘chatted’ with the bot Simon, and was directed to fill out a request, which I did and have a ticket number. They said they usually respond within a day. This hasn’t happened. It has to do with an overpayment which occurred when the public mobile site was not working properly.
05-08-2023 05:01 PM
Thank you for your advice. I did send a private message to the moderator and the issue is being resolved.
05-07-2023 04:15 PM
Thank you. I will continue trying to rectify this.
05-07-2023 03:56 PM - edited 05-07-2023 03:57 PM
Neither would I, @jweatherson
I remain confounded that some folks would load $100's onto their account given if they decide to move elsewhere, that money is gone and non-refundable. However for some, that's a budgeting method, I suppose.
If there are actual settled charges to your payment card, definitely request that PM refund them on the basis of the system problem you experienced. I'm certain they will in the circumstance that they were not intended as multiple payments.
05-07-2023 03:28 PM
Thank you. Will check but I see currently the amount as a credit on my Public Mobile account.
I was making a payment for added US coverage and it showed an error msg of ‘oops can’t be completed’. Tried several times. Same thing. Checked my credit card and found I had been charged 10 times but no balance showed on my account until later. I don’t want a credit of that amount sitting with Public Mobile! Still haven’t heard from them.
05-07-2023 03:24 PM
Thank you
05-07-2023 03:23 PM
Thank you. Checked. No msgs
05-07-2023 02:27 PM
I've been waiting over 58 hours and submitted a new ticket a couple of hours ago. It's been a bit frustrating. Hope you get a response soon!
05-07-2023 01:41 PM
indeed, over payments can usually be left on the account as a credit toward the next renewal.
There are also instances where a presumed overpayment with a credit card transaction shows as pending, however, that payment may also fall off within a day or two, and not actually settle as an authorized one.
05-07-2023 01:38 PM
If you have not heard in 48 hours, I would either submit another ticket or private message the CSA directly. No confirmation, but I have a feeling that there were some ticketing issues over the weekend.
Send a private message to moderator through the following link :
05-07-2023 12:56 PM - edited 05-07-2023 12:58 PM
anytime within 24 hours.
Have you checked to see if you already have their response ? Here's where you'll find it. There will be a number beside the envelop icon...
If it's been longer than 24 hours, I'd send a follow-up .
05-07-2023 12:52 PM
In my past cases they responded within a couple of hours. If for you it's been days, would suggest you try again.
05-07-2023 12:51 PM
The few times I've needed to contact them they've usually responded within a couple hours. Hopefully it won't be too long now.
Would it just be easier to leave the overpayment as a credit for next months bill?
