05-25-2022 06:46 PM
I have been waiting for over an hour and sent multiple tickets with no response. Starting to get extremely frustrated. Is there any way to contact someone directly that can actually assist me
05-28-2022 10:21 AM
CS agents are like toothless tigers, they can only help you with basic info that can be readily obtained by members on this forum. Perhaps you can post the problem and get help from members here at this forum.
05-25-2022 08:40 PM
Hopefully you get a response today, definitely no later than tomorrow morning, either way I hope it gets sorted out as I didn't realize the changing your number feature can cause so many headaches, seems to be relative seamless from previous customers in the community
05-25-2022 08:16 PM
Any response yet? If not I can send a message on your behalf as there is a very weird glitch of tickets and private messages not seen by customer support. Very rare but can occur....I know because my account does it at times.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-25-2022 07:46 PM
@Kjtoffle wrote:Yes changed the number since then and no I can't do anything other then use wifi on my phone right now
@Kjtoffle oh, now I see in your 1st post you did go back and change the number again.
Maybe, these posts will get moved or merged...so there isn't two going on.
Can you confirm your account status is showing ACTIVE?
While you wait for CSA to respond, if status is ACTIVE, try listing your phone into LOST/STOLEN mode under the "Plan and Add-ons" section TAB to suspend your account.
Restart your phone at this point, wouldn't hurt. Any services working on your phone?
05-25-2022 07:41 PM
@Kjtoffle don't hesitate, write another message and this can speeding it up a bit
05-25-2022 07:40 PM
05-25-2022 07:37 PM
@Kjtoffle wrote:it shouldn't be my phone it was working fine today untill I changed my number !
You mentioned someone else answered before, when you called it. Did you change the phone number again in your self serve? Because if someone else answered, then either you dialed the number incorrectly, or that number was mistakenly made available to choose from.
So best to go back and change it.
Again...can you make outgoing calls, text in/out and able to use your data?
05-25-2022 07:35 PM
05-25-2022 07:34 PM
Yes one was sent 3 hours ago and one was sent two hours ago no reply to ether. I do not have another phone that I can use to try the SIM card in
05-25-2022 07:30 PM
@Kjtoffle - oh yes, now I see your other post.
Can you make outgoing calls, text in/out and able to you data?
As for the tickets to customer support, you said multiply over an hour ago, how many did you submit?
I submitted one about 20 minutes ago through SIMon, Get Help With SIMon the Public Mobile chatbot
16 minutes later I got a response back and all ready to go.
Can you check to make sure you have the SENT ticket messages under the envelope, top right of your community page? You will just need to toggle from the INBOX messages to the SENT ones to see them.
Just making sure you see you submitted successfully.
05-25-2022 07:29 PM
Sorry, I didn’t read your other post. Sounds like rebooting your phone didn’t work.
Is it possible to see if your SIM works in another phone to eliminate the possibility that the phone is not the problem.
If it doesn’t work then it is an backend problem with the SIM but I am surprised that an @CS_Agent didn’t get back to you.
If it works in the other phone then it is your iPhone that is the problem.
05-25-2022 07:19 PM
Already tried that changed my number didn't work tried again now still not working and my lte abs service just keep flashing can't make calls or nothing call the new number says not in service
05-25-2022 07:17 PM
05-25-2022 07:05 PM
You can also turn on email notifications for private messages and when they respond you will get a notification in your email. Then come back here and deal with it. But that of course depends on how often you check or have your email set up.
05-25-2022 07:01 PM
@Kjtoffle wrote:That's crazy basically just have to sit and stare at my phone untill i get a message
@Kjtoffle - if you are on your community account now on your phone, then yes, you will need to be logged into your community to receive the INBOX message back from customer support.
Keep checking the envelope at the top, right of your community account for any new messages.
05-25-2022 06:53 PM - edited 05-25-2022 06:55 PM
The get help pages says it sometimes takes up to 48 hours for a reply during busy periods. They usually get back to you within a couple of hours.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
05-25-2022 06:51 PM
05-25-2022 06:50 PM
You will just have to wait. Keep an eye on the envelope icon in the top right corner for a reply.
