Crashed while setting up my SIM. App doesn't let me proceed.
Eddie6818
Phone application crashed while setting up for a phone number transfer.  Can't get past the "Register a SIM now for it says that it's already in use.  App prompts me to log in for further action, but nothing is happening.
Eddie6818
I was in the process of transferring my old number, so I havent reached the step to insert the bew SIM card yet.
hi @Eddie6818
you are setting up physical sim? did you try to put in the PM sim and see if it connects?
if not, ask PM support agent to help,  submit  ticket by direct message:
slusagm
and you tried to reboot phone and try login the app again?
time to ask PM to help.
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
