Roaming
Achy
Does Canada USA Mexico plan include roaming
DDM69
Make sure data is on and roaming is enabled on your device
hi @Achy
yes, the Canada USA Mexico is a roaming plan. Basically you use data, call and text in US and Mexico like you are in Canada.  For calls, you can make calls from and to within the 3 countries, all included
slusagm
yes, it does
