Can’t get into my acct/eSIM not working
Stephanie0126
Just created acct and activated new subscription. eSIM I pruchased not working, and I cannot access my acct as it wants to send a code to the NEW phone number on the eSIM that won’t activate on my phone. Nothing I try will allow me into my account to do anything as it won’t let me pass the beginning stages of verifying my identity.
Very frustrating 😞
Would be so nice if I could speak to an agent over the phone. Very inconvenient 😤
2 REPLIES 2
slusagm
@Stephanie0126
for the eSIM, check if it is installed on your phone already.  Make sure you removed the old carrier sim card and disable old eSIM.  PM sim should be the only one there and enabled
Try reset network settings and check if the phone connects to PM network
if you need PM to help to reprovision the account, please submit ticket.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
@Stephanie0126  sorry no live support you instead have to engage support by
sending   a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
