Lost access, Paiement problem
Joly1
My phone number is xxxxxxxxxxxxxxxxxxxxx
2 REPLIES 2
slusagm
remove the phone number, we are just customers
ask PM to help with login.
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
or if you need to renew plan first, buy a voucher from Shoppers drug mart and log it via *611
@Joly1
send  a  private message   To CS_Agent
