12-30-2022
05:26 PM
01-07-2023
10:56 AM
Dunkman
Is public mobile going to catch up with the new towers out west or am I switching to rogers?
12-30-2022 06:08 PM - edited 12-30-2022 06:09 PM
@Meow wrote:
@SKnight wrote:No threat or blackmail here. Simply curious if PM is going to get with the new technology?
We are all customers like yourself here. HOW are we supposed to know???
Hi @Meow that is untrue, I see many members know a lot. Some works in the field and do a lot with towers and the technology. I don't see any problem OP asking that. Through discussion, we can learn more. Don't be harsh to OP
12-30-2022 05:51 PM
Public Mobile is Telus. Telus uses Bell. Bell uses Telus. Public Mobile, Lucky and Chatr still use 3G/UMTS systems for talk. Chatr might even use the yet older 2G if available whenever Rogers gets around to shutting that down.
Freedom still uses a 3G frequency not used here.
But they all otherwise can use VoLTE which the three I listed for 3G do not.
Telus seems to be making network changes that may very well be squeezing out old 3G customers in some areas.
Did you try forcing your phone to 3G? Might be worth a shot.
12-30-2022 05:39 PM
12-30-2022 05:37 PM - edited 12-30-2022 05:39 PM
@SKnight @I’d definitely go with a provider that has coverage where you live
Do you have coverage where you live now ?
maybe stay where you are forget robbers stay away !!
12-30-2022 05:35 PM
Thanks anyways. Rogers, Fido…etc all have coverage in the area I live. But not Public Mobile. I’m asking if they will be catching up or should I switch to a provider that has coverage in my area?
12-30-2022 05:33 PM
@SKnight don’t know if this helps
Coverage map in your area
www.publicmobile.ca/en/on/coverage?gclid=CLuo4c39yNQCFQQvaQodeZEC0g
12-30-2022 05:30 PM
12-30-2022 05:29 PM
HI @SKnight
We are all customers here like you so we don't know too
Which city and province you are in ?
Try to open ticket with Cs agent and ask them:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-30-2022 05:28 PM
You have to ask management this question. You are free to switch to any provider if service is not satisfactory to you. Threats and blackmails have no influence here...
