2 hours ago
- last edited
5m ago
computergeek541
Hello,
Since PM doesn't sell phones directly, I'd expect PM to have Volte support on all phones sold under Telus/Koodo network.
I have an iphone 7 which support Volte on Koodo network but not in case with PM.
All new phones sold by Koodo/TELUS in 2018 or later and most sold in Canada will work on the TELUS VoLTE network.
an hour ago
I have a friend with an iPhone XR that was sourced from a competing brand that does not get VoLTE. The VoLTE and 5G whitelist is one of the negatives with this service.
2 hours ago
HI @inonosa
from what we see, PM just add newer phone onto the VoLTE whitelist but not older phone. I don't think PM will add iPhone 7 on unless they start allowing ALL VoLTE phones here. But you can check with support agent instead
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 hours ago
test things out yourself...turn off wifi and dial a local number. Does your cellphone drop to 3g or does it stay on LTE ? If it stays on LTE, you're good to go.
2 hours ago
the phone will still work on PM but will be using 3G for voice. With PM, you need to have an iPhone 8 and above to use VoLTE
