Community Rewards
raymondzhou122
Hi, I don't really understand how the community rewards work?
Is it like a points system and if you earn enough, you are eligible for the rewards?
And secondly how do you earn points or the rewards?
1 ACCEPTED SOLUTION
Accepted Solutions
@raymondzhou122
Community Rewards are awarded by your contribution (time spent in the Community forums) measured by bravos/posts/solutions you receive.
There is no exact way of knowing  (it is top secret).  😛
But if you read up posts and know answers to some you can contribute by either asking or answer them.
There is no set /written limit to how much time, bravos, answers, questions you need to be involved in to receive community rewards
Spend time reading posts, asking questions and answering when you know you can help and you will likely be rewarded!!
Additionally, you could contribute for one 30 day period, get rewarded; then the next 30 day period it resets, so you would need to continue to contribute for any rewards to be given on a continuous basis.
But if you take a break, no worries, just come back when you can!
14 REPLIES 14
@raymondzhou122
Hi @raymondzhou122 , it's not points to earn.
Basically you need to participate as much as you can.  Reply questions that you have  the answer.. bravos other's good reply and have others to bravos your answer.
at the end of the month, depends on your participation among others, PM will award different level of Community reward , $1, $2, $5, $10, $15.  However, there is no solid number to how to earn the different level of reward.  it is a relative performance and it is a secret that only PM knows
So, start slow, come here for an hour or so.. start answering and start bravo others.
HALIMACS
Hi @raymondzhou122
You've already began by posting on the forum.
Basically, be responsive, helpful, courteous.
It's best to be brief and precise, and recognize others for weighing in.
Eventually, you'll receive bravos and solutions, and in time, will get a share of the pie.
Heck, I'll even bravo your first post to get you started!!!
raymondzhou122
When does the new cycle for the top 50%, 10%, etc start for the community rewards?
LegusY
I believe its each calendar month.
@raymondzhou122  It is counted by calendar month.    Around the 7th of the following month, they will put the Community reward amount, if you are eligible,  into your account and could be used for your next renewal if you are on the old rewards system.
If on the new rewards system, they will add the point to your account couple days later.  Once you collect enough for 15 points  , then you can redeem for $15 bill credit
MrSpock
@raymondzhou122  Hi it’s the beginning of each month announcements for last month are usually made the second week in the following month
