City I live in
09-14-2022
05:12 PM
09-14-2022
09:37 PM
computergeek541
I updated my address to alberta. The system says Okotoks is not valid but I live there. T1S xxx even says it is valid
My Account
09-14-2022 07:58 PM
@CountyDownIeUk- The system will not let a leading or trailing space nor a space in the middle by typed.
09-14-2022
07:57 PM
09-14-2022
09:40 PM
computergeek541
Did you enter.
T1S xxx
OR
T1Sxxx
09-14-2022 05:16 PM
You don't need any support. The address has no effect on anything here. To get past the limited selection of cities to complete any of those changes just pick whatever city.
If you have a phone number with an area code not from AB then you will be charged the taxes of that province where the area code is from. If you want to pay AB taxes then either change your number or or buy vouchers in a store in AB.
09-14-2022 05:15 PM
Address does not matter much to PM. They will never send you anything. Unless you buy a used phone then you will have to provide correct address.
09-14-2022 05:14 PM - edited 09-14-2022 05:14 PM
@tonyfielding all cities and towns are not on the list just pick one that is close to you
09-14-2022 05:14 PM
Hi @tonyfielding the city list there does not cover all cities , so, just pick on close by you 🙂
09-14-2022 05:13 PM - edited 09-14-2022 09:40 PM
removed nonsensical reply
