11-21-2024 07:45 PM - last edited on 11-21-2024 07:49 PM by computergeek541
I am currently in Washington, USA for 2 months. Is there any way to check my voicemail?
Do I need the 15-day roaming addon to check my voicemail?
11-22-2024 12:27 AM
11-21-2024 10:14 PM
@bau wrote:My public mobile sim is unable to make any calls while in the US.
I used a different phone to call my public mobile phone number, waited for the voicemail prompt, and pressed '*' to enter the voicemail menu. A VoIP service also works for accessing voicemail.
Thank you for confirming this. I just wanted to make sure as Public Mobile is one interesting service. You can receive text messages while in the US without a sub or addon but can't send. Hence the reason I asked. 🙂
11-21-2024 08:30 PM
11-21-2024 08:27 PM
why not? Try yourself with a landline. Call yourself and enter * at greeting
when you are in US, call using VoIP app so you can call for free or you can call using landline with LD fees. Or instead of calling your line, you can call one of the 4001 voicemail number
Test it yourself
11-21-2024 08:21 PM - edited 11-21-2024 08:22 PM
11-21-2024 08:10 PM
Pressing '*' during the voicemail system message seems to have worked. Thank you!
11-21-2024 07:52 PM
Hello @bau
To use your phone in the United States, you are required to either purchase a US add on or have a Canada/US package. There is no charge for calling your voicemail if you have these two options. If you don't, you would have to dial your phone number from somewhere in the US and pay fees.
On that note, I would strongly look at the Black Friday plans that came out today. There is some SERIOUS value there for Canada US plans.
11-21-2024 07:46 PM - edited 11-21-2024 07:49 PM
yes you cam check voicemail without roaming
To check voicemail, use some VoIP app to call for free (or you can also use landline) to call yourself and click # as your voicemail greeting starts, then enter PIN
