Voicemail
Redrooster
Why some times does my voicemail ask the caller for their name then tells it to me when I access the message?
7 REPLIES 7
hi @Redrooster
you have been with PM for a year, so your Koodo acccount fully closed right?
you can still try open a ticket and will see, maybe they reset the voicemail and will clear up some glitch at the backend
submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
Redrooster
So no point in opening a Ticket then?
Redrooster
As you can see above I have been with Public for more than a year. Previous to that I was with Koodo. I never had this problem with Koodo. Since it is part of the voicemail greeting message I thought it must be doing it on the network side and was hoping for a solution to get it turned off.
hi @Redrooster
then it is weird.  What you are experiencing is Call Screening, PM does no have it.  And I don't think it is anything related with device settings
Redrooster
I have been with Public for more than 1 year now. I looked through the settings on my Android phone and I don't see anything related to "Call Screening". Like I said this only happens occassionly.
Anerkons
Check your settings - you may have enabled this feature. Under your settings there are the options under Phone and at the bottom SCREEN CALLERS. Check if you had enabled any of the screen  features. I have set mine to none.
hi @Redrooster
that is Call Screening.  PM does not have this feature
did you just join PM? if so, your porting request was not competed, you line with the old provider is still active
